MiniGibbo
No Indy Or Repeater.
MiniGibbo
As above I've lost the passenger indy and repeater..
What do we reckon bulbs or something more sinister.?
EZ Tutty
In the engine bay follow the wiring back from the offending indicator, it should go to a plug with another set of wires coming off the same side (for the side repeater), and a single pair on the other side (feed from the indicator relay), usually it's this pair of plugs that cause the problem, trying cleaning them, or better yet do what i did and just chop the plugs out and solder the wires together.
The only reason this pair of plugs is there at all is due to the fact some 205's didn't have side repeaters and rather than modding the loom they made an additional mini 'link' loom to run the side repeater.
They're on the same circuit so you'll lose both if one's dead iirc.
Probably just iffy/corroded connectors.
if youve lost both it'll be the sub-loom connection just behind the headlamp, brown two slot plug.
MiniGibbo
Cheers lads I'll have a look when I get chance..
What is it with old French cars and earthing problems LOL
Whenever this happened on my cars its been the brown connector near the headlamp dragging the earth down.
Strangely, sonce re-doing the headlamp panel earth points to all ring terminals on the bolt, it hasn't happened again.
g
MiniGibbo
Yeah I've just had a look and made sure all the plugs where pushed in and none of the wires have snapped.
Hasn't fixed it and that's as far as my wiring talent goes lol..
Back to miles the car will go.
pull the plug apart, clean terminals, push back together giving it a damn good wiggle as it goes.
