fordygti
What Gearboxes Will Fit An S 16 Block?
fordygti
As above really. I have a gti 6 box in the 205 at the minute. And the right hand hand lock is very poor. And I'm looking at a box that will give a bit more acceleration.
Liquid_106
1.6 box will give the best acceleration, but you'll suffer at the top end - motorway driving would be an issue too.
fordygti
I'm not fussed about top end. What do you mean by an issue?
Liquid_106
Well 'issue' maybe too strong a word. What I mean is that you'll be higher up in the rev range at motor way cruising speed, so noisey and less fuel efficient. There are some good threads regarding gearbox choice and intended application. You can even create a hybrid a box with different crown and pinion selections, so the world's your oyster - just have a little search as I know it's been covered before in detail ;)
fordygti
Ok, ill have a dearth, thanks for the advice.
Be realistic about what you want from the car, I do probably 1 long journey in mine per year down to Pugfest, so I can put up with the short gearing of the 1600 gearbox as it makes the car accelerate like its tyres are on fire. It will sit happily at normal cruising speed of 70-75mph doing around 4000rpm.
wicked
The problem is the 6 gears.. That's makes it larger.
You can also take the box from a Xsara VTS (with the same RFS engine). That has 5 gears and matched with the engine.
fordygti
And gives a terrible right.lock.
Edited by fordygti
wicked
The xsara box is not the same as the gti6 6 speed box...
It's a 5 speed box and smaller, just like the 1.6 box... Only the gearing is different
fordygti
I meant the 6 speed box gives a terrible right lock.
So for acceleration go for the 1.6 box
And for normal comfy use, use the vts box?
bertie_bas
I found the 309 1600 on carbs had closeish gears 1st to 4th and a taller 5th for the longer runs....
Very close to the 1600 box with a taller 5th if ye like...
Bertie.
wicked
For normal use, stick to a VTS or S16 box. These are shorter than the 1.9 gti box and might suite the engine better.
1.6 box is really short. It's big fun, but as a daily it would get annoying....
fordygti
Thanks for the advice, 1.6 box its is, its only a weekend car really.
cybernck
I don't think you'll get what you want that way, as you'll only get a shorter 1st gear and loose the 6th.
I mean, the car shouldn't behave much differently, but you'll get your lock back for sure :).
Take a look at this table of gear ratios and speeds: http://www.205gti.com/techgearboxUK.htm
fordygti
Thank for the link. From what people have said, the 1.6 box is shorter through all gears?
Shoebox gti
my old mk2 escort was fun on a long trip 90mph at 8+k with sportex 2.5inch straight thru im still death :blink: lol
