Pazzapug
Flywheel Skimming
Pazzapug
Hi all,
Does anyone know where I can take my flywheel to be skimmed around the Chester/Cheshire area??
Any competant machine shop will be able to do it. If you find your local engine reconditioners they are probably favourite as they will most likely have done plenty before. Note that the surface does have a small step in it from the friction face to the pressure plate register, and this needs to be copied.
