dave205
Gti-6 Sump On Turbo Engine
dave205
Is this straight fit?
S@m
I believe its the same sump, at least everyone i have seen is the same with the baffle etc.
Sam
yup will fit no probs but you might have clearance issues with the alternator bracket, use the gti6 bolts.
dave205
When you say clearance issues do you mean were the bolts go up into the bottom of block?
no, depends which alternator bracket the engine originally had, some overhang the edge of the sump if it was a steel one, these would foul on the alloy sumps, you'd need to trim the bracket or use a gti6 alternator bracket.
