Nath88n
Break In
Nath88n
Was cleaning the car today and noticed these scratch marks on my drivers side window, no marks on the door frame though.
Really annoyed as all the glass is matching with number plate etchings.
Do you think someone has tried to break the window? Or is it something else?
Edited by Nath88n
can't see anything? :unsure:
if someone wanted into a 205 you'll either have a very bent door, or no evidence whatsoever if they knew what they were doing...
Nath88n
The white marks, you should be able to make them out?
I guess, the only other thing I can think of is if the window is moving in the frame when it's lowered.
chipstick
Whip the door card off and have a look and see if the glass is catching on anything.
Richie
Perhaps you rubbed past a stiff bush. So to speak. More likely its catching going up and down though.
McDude
It would be the most pathetic break in attempt if it was.
chipstick
Could have been a snail covered in gravel?
Weser
From the spread pattern it looks like someone has thrown something at it?
ALEX
Can that be fixed with those glass repair jobbies?
Or you must still be able to get number plate etching done somewhere.
