Alfie
Central Locking Relay
Alfie
At the risk of duplicating my post earlier, anyone know where it lives please? I've been searching all evening for a past enquiry on here. :unsure:
Assuming you mean the control module, it's the black box about the size of a glasses case to the left of the steering column (Phase 2 models only)
Alfie
Thanks Anthony. I guess I have to remove the bottom of the shroud then to get at it? As previously posted, I've checked the fuse but it still doesn't work the C/L. I thought that the relay might be suspect?
Edited by Alfie
Yes, remove the lower dash trim and you'll see it - should be next to the white lights-on buzzer (assuming that's still clipped where it should be)
Alfie
Thank you.
