Scruffy
Hubs
Scruffy
What hubs off other cars will fit a 205 1.9 gti as mine are worn were the ball joint fits in
Fit properly with the correct geometry? Only 205 1.9 GTi and XU engine 309's (inc GTi) I'm afraid.
306 and Xsara hubs will physically fit, but the geometry is wrong and you'll end up with positive camber.
Lesser spec 205's use a smaller spline driveshaft, so the hubs from those won't fit without also swapping driveshafts.
N3VRAM
without opening a new thread, do 1.6 shafts fit a tu3 (ma) gearbox?
Assuming you are talking about 1.6 GTI shafts, NO. The 1.6 GTI shafts are to suit the BE gearbox.
N3VRAM
Correct. Thanks for the info!
