Pete C
406 23Mm Bmc Swap
Pete C
Do I use the 406 reservoir that came with the master cylinder or is it better to swap it for the 205 one? :)
Normski
I used the 205 one as thats what I had. But if the 406 one fits, it wouldn't really matter which you used. Using the 205 set-up keeps things simple as it is a straight swap. I've not seen a 406 res, so I'm not sure how the low fluid warning switch is wired.
Pete C
There's a two pin plug. If I'd have thought about it, I'd have cut the plug off the 406 I took the reservoir from...
Alan_M
I think the connector is a 2 pin injector type plug, if you've a gash loom kicking about.
