starky5
New Rear Beam Time, Opinions Needed!
starky5
Well today my 205 failed its MOT on the rear beam and a couple other bits!
Just after some opinions, i have the choice of either a standard 205 1.9 beam or a 309 tube with 306 gti6 arms and i think berlingo torsion bars. The car is only a road car at the end of the day so i dont want to stiff a ride but i do like it to handle as well as it can so i can still have some fun!
Any info/views welcome
Andrew
standard 205 beam with a larger ARB, or 205 beam with 21mm bars works nicely on the road :)
decent dampers make a massive different regardless of spec though.
starky5
yea my dampers seem a bit ropey so ill be changing them at the same time
Wes
i went for a standard beam with 24mm arb from anthony and its great.
Henry Yorke
Standard beam with a thicker anti roll bar for a fast road car
starky5
Ok so ive ended up with a 309 beam as its already built and i can pick it up this evening! Probably not what i should base my decisions on but i want the car back on the road!
Now all i need to do is order some shocks as i dont fancy swapping mine or using the second hand ones that are being thrown in with the beam. Any suggestions on a good quality shock without spending a fortune?
Scrap that i just found a very useful thread on shocks through the search!
Edited by starky5
Guest
