Atreides
Best Place To Get A Refurb Rack From?
Atreides
I know the Peugeot racks were far superior to most of the rubbish that's about these days, so now that Peugeot have stopped supplying them, does anyone know of a decent place to buy a (decently) refurbed steering rack from?
dcc
low miler shell from scrap yard.
or buy a drive and spline kit from quaiffe and 'build' one yourself
What is the matter with yours? All that is usually needed is a new bush in the N/S end of the rack. You can of course inspect the rest and change the bearings whilst there, but in my experience they are usually all ok and a clean and re-grease is sufficient.
clen666
Is there a guide anywhere on how to strip a rack down and replace bearings?
I've a xsara vts rack that I would like to ensure is tip top before fitting
Atreides
I wouldn't mind knowing this, as well. My rack has a bit of lateral play on the N/S...
Tom, can you still buy the bearing separately (or even from Peugeot)? Do you happen to have any part numbers?
Alan_M
Do a search, as I posted a few lines on how to pull them to pieces several years ago.
On the bearing, depends which rack you have as a certain type has a unique bearing that seemingly is pain to get hold of!
