bobspugs
Still A None Starter
bobspugs
Hi,
With a 1.9 with motronic ECU which of the following if not working corrctly would prevent the ecu from fireing/earthing the injectors. SAD, injector temp sender, lambda sensor, tachometric relay any others i may have missed?
Starter motor turns, plugs spark, fuel to the injectors but still they will not operate?
Going mad!!
Bobpugs
Motronic car's do not have a Tacho relay, the main cause of that is the TDC sensor on the box
bobspugs
Thanks miles i will check it and have another go!
Bobspugs
