Terry1600
Annoying Clunk
Terry1600
my 205 has been developing an annoying clunk up front when I brake, I notice its worse when braking in reverse but its also noticeable when I go around corners or when I lift off the throttle its pretty bad. I've changed the wishbones, drop links, both front hubs and both rack and along with fitting two new shocks. everything was fine to begin with but has gradually been getting worse. i noticed a bit of play in the ball joint so i fitted a new pinch bolt and its now nice and tight and checked all nuts and bolts but its still there. i need help!
Terry1600
if i loosened both wishbines from the subframe it would make this noise on another 205! ill go check subframe bolts now
Terry1600
turns out im not as strong as i thought i where, got a bigger tool on the wishbone bolts and got another turn out of them and problem solved, cheers pal!
