Timmartin0
Fitting A Door Catch
Timmartin0
Hi guys!
Does anyone have detailed instructions of how to replace a door catch on my 1988 1.9 Gti. I have the new one, taken interior door panel off and then seen how little room there is, and was wondering how the hell you connect everything up - and do I have to remove anything else to improve access(ie window runners). Cheers in advance guys!
Weser
Not going to lie it is fiddly. I think the last time I did one I unbolted the bottom of the runner which allowed it to move out the way enough.
sharpm
did mine last week and once the door panel was off I just had to remove the speaker and there is plenty of room to get your hand in with a small rachet or a spanner.
didnt remove any window runners or anything else like that.
gavbrum
Is it the door arrester? The spring hinge that holds the door open?
If it is then as above. Just take the door speaker off which allows you to remove the bolts for the arrester. Then pop the hinge pin out and repeat process in reverse to attach new ones. Pin is a bit fiddly.
It is a bit awkward, but you have the good advantage of having a new one in your hand so you can see where things connect without having to stand on your head inside the door to see what is going on. Most of the clips that hold the rods unclip by pivoting round before you then slide the rod off.
