VND
Xud Fuel Pump Swap
VND
Morning all, need a bit of advice if possible.
Im looking to change the fuel pump in my 1.9 non turbo from a Lucas, to a Bosch (to cope with veg oil).
Im not sure what needs changed though.
Do I need to switch just the pump inself?
Many thanks for any help yous can give.
Edited by VND
You need pump, injectors, fuel lines from pump to injectors & iirc some injector seals from pug.
There is also a stud on the mounting bracket which needs relocating but the thread for it is already in the bracket, you'll see it when you take the old pump off.
g
VND
g
Sir, that is epic info.
Thank you very much indeed.
