Iain-gti
Brake Lines For Bais Box.
Iain-gti
Hi,
just started running brakes lines front brakes one master cylinder rears another. Just trying how to connect both front into one cylinder yet keep it looking neat. Any ideas???
allanallen
I used 2 cranked banjo fittings and a double banjo bolt. I believe you can get double banjos though.
No pictures sorry although I can get some in the next few days if your not in a rush.
Iain-gti
No need for pictures, i understand. That sounds like a good plan and you can get double banjos. thanks
Iain-gti
whats cranked banjo??
I'd get a Tee piece off a non abs 306 or xsara in a scrappy :)
allanallen
Do they screw directly into the m/c?
no, they sit on the bulkhead just behind the gearbox :)
Chris H
you can buy double ended banjo bolts if your doing flexi pipes
