cleggy
Strange Oil Pressure
cleggy
Hi, just a quickie hopefully. When I start my 1.9 205 turbo from cold the oil pressure gauge shows the pressure rising but not smoothly whereas all the other 205's ive owned did, it does get 3/4 of the way across the gauge after 5 seconds or so. When i drive it after its warmed up the pressure then drops to a quarter of the way across the gauge so 2 notches or so. I'm gonna take the sump of tomorrow to have a quick look at the scavenge and such, is there anything else it could be? Could it be crappy oil or something?
Regards Phil
Leave the sump alone, most likely of all us a duff sender or wiring. The standard gauge is at best a rough guide, in general a guessometer and at worse just incorrect.
cleggy
Is there any other way if checking it? I was on verge of getting a spring and plunger etc for the pump
Fit a proper mechanical gauge.
All this has been discussed many times before if you have a search.
cleggy
Cheers mate
