omri617
No Beeping Sound When Lights Are On And Car Is Off
omri617
Hi ,
i noticed that i dont have the beeping sound anymore when front lights are left On and car is
not running and door is opened
what can cause this?
also , where is the Horn fuse? 205 Gti 1992
thanks..
Strictly_Derv
I thought 205's didn't have that feature, or is it just mine? :o
DaveW
Its a buzzer under the dash, i think its white box shape under the driver side, where the little storeage tray is( that is if your car is RHD?)
Does the door open switch work properly? If not, the lights on buzzer won't work.
marksorrento205
As Anthony said :)
omri617
my car is left hand drive
stripped down the whole car cant remember i saw something like this
any picture or more details would help..
omri617
yes , when i open the door , the light inside turns on
Simes
My buzzer stopped working, swapped it with one from a 306.
omri617
where is it located ? to what it's connected?
Only seen them on phase2 205's, its a white box that looks like a relay, only 3 wires to it, can't remember where it is on a 205 though, 306 and 106 buzzers are the same.
Phil H
clipped onto the lower steering column bracket on a rhd.
Paul_13
I got my interior light working when I change the door switch, scared the s*it out of me when it started beeping again :lol:
lemmingzappa
I wasn't even aware my old Phase 2 had one until now :lol:
MiniGibbo
I never had one but Miles fitted one for me when he did the rewire..
Ultimate lad :D
omri617
Well , managed to find it , apparently i had to disconnect 1 of the wires )the left one( to make it work again .i think it's related to a mess was done on the instrument panel where i worked on.
here is a photo
Josh_Quant
Would it be hard to wire one of these up then if you haven't a phase 2 gti?
Phil H
three wires....run one to ignition 1st position feed, run one to lights positive feed and one to door switch earth wire, the relay even has pictures to guide you.
omri617
so why did i have to cut on of the wires to make it work again? i had to cut the orange one...where do you think it goes?
christopher
What is its function. Apart from an annoing beep?
My guess would be that the ignition feed wire is constantly live for some reason, as this would stop the lights-on buzzer from working correctly, and cutting the wire would address the issue (but means that the buzzer will now sound even with the ignition switched on, which it is not meant to do).
(note - I've not checked the wiring, so I'm guessing that orange is the ignition feed)
tell you youve left the lights on :lol:
chipstick
I may chop the one out of the ph2 and try and retrofit it in my ph1.5.
I posess a mulitmeter now, so it's a good excuse to get out and learn how to use it :lol:
christopher
Ha Ha ..oh....THAT....beep, thats a buzzer:-)
I'm sure my 205 used to beep 4 times when I turned the ignition off. I always thought it was the SONY radio. In europe our lights come on automatically with the ignition on, so no need for a buzzer.
Edited by christopher
omri617
in my car , when i only turn the parking lights , the sound is different a bit from when the headlights are on
at first , it sounds like , it's running on shortage of Volts. like gruff
