bl4ck clio
S.a.d Vs Icv, What Different...
bl4ck clio
as topic,
anyone can explain, what advantages/disadvantages of that devices?
as I know, ICV controlled by ECU...what about S.A.D?
is ICV better than S.A.D?if yes, on what case?
thx.
SAD - open when cold. As it heats up from +12V, the orifice slowly closes over, shutting off bypass air around the throttle. Takes approx 10mins. The orifice is adjustable. Adv is simple but crude.
ICV - pulsed width modulated +12V from the ECU controls a barrel valve which varies amount of air bypassing throttle. Adv is more consistent idle speed.
camgti
Which are on which model Pete?
vinorak
gti 8v...SAD
turbo and 16v... ICV :)
Edited by vinorak
I should add that Mi16 is 2 wire PWM, where as GTi6, XSi etc. is four wire stepper motor (completely different). SAD was fitted to anything Jetronic, 505 included.
Vili
And 2.0 mi16 /306 S16/XU10J4 is 3 wire PWM
