omega
When Is A 205 Not A 205?
omega
after reading about the 205 evo project where someone said they didnt think it was a 205 anymore, when does a 205 become something else? or stop being a 205?
is it when you fit a mi16,gti6,turbo engine etc,or is it when you bolt on a 309 rear beam or fit bigger brakes?
all the above things change the car and how it feels and goes so does this mean its not a 205 anymore?
just wondering where you draw the line
The line is drawn by the DVLA with their 8 points system, various parts are allocated a certain number of points and you need to retain at least 8 points from the original car or you lose the right to registration as the original model. The Evo project wont score 8 points as a 205 or an Evo and would be considered a cut and shut so needs to go through a IVA/SVA/ESVA test a bit like a kit car. Once it passes it would be allocated a Q plate and the owner can choose a manufacturer name and model for the V5 but from what I understand it cant be a trademark so needs to be original.
http://webarchive.na...cle/DG_10014199
MiniGibbo
Never knew that..
My Bmw just scores 8 soon to be 7 followed by 5........
Cameron
I think that as long as it still has the 205's silhouette, it's a 205.
My project will still be a 205 as far as I'm concerned, I don't care what anyone else says. :D
RossD
This is going to be blasphemy to some people - But to me a 205 is a lightweight shopping hatch with a small engine. A fun 205 is a lightweight slightly stiffened, lowered 205 with a small revvy engine and snappy on the limit handling.
As soon as we start putting massive brakes on them and big heavy 2.0 engines, they start moving away from my 'ideal' vision of a 205.
Even my 205 is not what I think a 205 should be really - Its got a cast iron 1.6 engine in it, when in fact it should be a nice light revvy alloy 1.3 or 1.4. Lots of revs and a not too much power make for a fun car :-)
The proper 1.3 TU24 to me is the ultimate 205. It might not be the fastest thing in a straight line, but that buzzy, revvy little engine and lovely steering and handling get close to what a true 'hot hatch' should be.
Now class, in conclusion, when is a 205 not a 205? Well, when its got more than about 130bhp, weighs more than 900kg and has big brakes (i.e GTi-6), has an engine bigger than 1.9 litres (Preferably 1.6 or smaller!) and is trying to be something it's not!
Now, having in mind I have just alienated most forum here, I shall bow out and await the flaming :-)
Edited by RossD
Cameron
I agree about the small engine thing, makes me glad to have a 1.6! :D
Disagree on everything else though. :P
  On 5/23/2012 at 6:58 AM, MiniGibbo said:
Never knew that..
if its all BMW you'll be fine.
stu8v
Engine size is no issue to me as long as its not a turbo and revs.
Chassis should be broadly as it came out the factory too IMHO, Other wise your just building 205 shaped a kit car.......
Weight should be <800kg
good luck, most stage cars are easily 900 kilos :lol:
Cameron
I might change my thread title to "Ultimate 205-Shaped Kit Car" then. :P
Except I don't know of anywhere that makes one in kit form.. how about "Ultimate 205-Shaped Custom Engineered Race Car"? :lol:
Batfink
It does not really matter what engine is in it. Its a true 205 as long as the chassis is there imo
Camerons is going to be a silhouette racer but it will look like a 205 so you might as well call it a 205 even though theres hardly going to be a 205 part on it.
The 205 T16 is called a 205 by most and thats only because Peugeot marketing department made it vaguely look like one.....
rallyeash
Sounds to me like some people have never had a decent engine in a 205, just because an engine has bigger pistons and produces more power it isn't then a 205....
Sounds similar to the old Id rather have a 8v 205 over a gti6 engine as its more torquey.....
Cameron
Good point, the T-16 was not a standard 205 by any stretch of the imagination! :lol:
Even the homologated road-going ones were nothing like it.
Richie
If it looks like a 205, its a 205 to me,
But they came out before the 205 road cars, so which one isn't a 205? :lol:
stu8v
True,
But given it was given the "205" name by Peugeot and that makes it a std 205 albeit a "std rally car" LOL
Much the same as the 6R4, Delta S4 etc etc
Edited by stu8v
McDude
Any change to a car makes it less like the original and at some point it is so far removed it is now something unique. Jack Herer's post says the DVLA has already had a discussion on this and written some rules and guidelines on it.
As fo the T16; it's not a 205 really, is it? Engine is in the middle, driving 4 wheels, chassis is mostly spaceframe. I think only the doors and lights are common with our 205s - hell there's more common parts on a Citroen Visa!
Henry Yorke
It is a Peugeot 205 if it says it on the log book. If it breaches the DVLA definition then it is whatever you want to call it. What you are now discussing is what is the spirit of a "traditional 205". Anything non-standard is a step away from that. Personally I think the 1.6 is more representative than the 1.9 of the 205 ethos
