mang
Fibre Glass Bonnet
Liquid_106
I think they are the version the you bond on to the existing support frame as a replacement for the original skin. As such, I don't think you could use it by itself as would flex for too much, there doesn't look to be any support structure underneath.
I could be wrong though ;)
BlueBolt
Looks like 6 bonnet pins in need at least... 4 along the front, 2 at the window side, and sod the support lol
Would imagine it would have a fair amount of play in it though, looks very thin......
Batfink
last time i had something similar I fibreglassed a plastic tube across the front to help limit bonnet lift.
MiniGibbo
Youd be ok with four pins on that wouldnt you..?
BlueBolt
More than likely but I recon it would look menacing with 4 along the front lmao :lol:
Liquid_106
Prediction
:P:D
BlueBolt
Tasty!! :lol:
Slo
mmm arent you just supposed to tigerseal it on top of your existing bonnet? or is it just me or what?
MiniGibbo
How would that save weight, that would add weight lol..
Slo
well again is it just me? who said anything about weight? its available cos everyone wants a proper one theyre just trying to cash in on the market but i take your point so dont grill me
mang
I know it will flex quit abit just wanted to know if anyone had brought one of these prticular ones because I dont know how much it will flex till its to late im not woried about puting loads of pins in it the cars not an oil painting any way ;-)
Batfink
it will flex a lot. Lots of pins looks stupid.
Liquid_106
If you don't want to do the full bonnet 'internals', take just the front section as it'll give you support for the bonnet pins and also stop any flex. Could also do the back corners and keep the hinges?
Gentrix
At least a cheap way to get a mint auto-bonnet.
Liquid_106
I doubt the fiberglass would be a mint finish - would probably require a similar amount of prep as a non A1 auto bonnet to get it perfect.
