iPlod999
Oil Tempreture Cable.
iPlod999
The guage has never worked in the car since I got it. So today I decided to see if I could get it going.
On the back of the top of the engine I found 2 plugs. One with a purple cable and one with orange cable. Both have power going through them. I swapped them around on the connectors the were on. The oil tempreture gauge was now rising. However, the water temp gauge do not move.
OK. So I realised that the orange cable was for the water tempretue.
Is the purple cable for the oil tempreture?
If it helps I will try to post some pictures tomorrow.
Cheers.
Slo
My oil temp guage doesnt work either and heres why, the white wire has broken off because of the temperature from the exhaust manifold. If i earth it the guage sings and dances so this is the wire you want for the oil temperature
iPlod999
Cheers Slo. I ll go and have a look. Now, where's my torch!!!
iPlod999
No joy. I may have to use 'fresh' eyes in the morning!
I could not spot the black sleeve with the white wire coming out. Is your picture from above with the air filter removed.
I found a connector on the bottom of the sump with no wire. I imagine this is where the oil temp is taken from?
Slo
yup at the back this is the oil temp sensor. the white wire comes from a 3 pin brown multiplug that connects to where the main engine loom ends/connects round about in front of the thermostat/sad/temp housing its easy to spot white yellow and purple wires
