dave205
Saxo Driveshafts
dave205
What driveshafts fit a saxo a vtr? Can they be used on a 205? Or are they the same as tu ones?
106 and ax fit, splines same as a 205 tu but different lengths, late (post 99) have a tapered seat on the cv a different wheel bearing id+larger od hub flange which is not compatible, though the complete hub+shaft can be used if required
dave205
So 106 1.1 shafts will fit on a 1.6 saxo vtr then?
They will fit either end, one more detail I perhaps should have added is that the sportier models use an intermediate bearing carrier and a stronger inner CV.
So a passenger side shaft should fit, but I wouldn't like to say how long it'll last.
