MattCoggins
Ma Rallye Linkages
MattCoggins
Ive currently got the gearbox out of my Rallye.
I want to change the gear linkages to hopefully get rid off the slop.
Ive looked on Ebay and can only find kits that have 2 rods... I need three!
Ive measured the rods, they are 4 inch, 13 inch and the one from the gear lever to the sub frame is roughly 28 inch (i couldnt be arsed getting under the car to measure it accurately)
Can someone point me in the right direction please?
Cheers Matt
drop miles at pugracing an Email :)
edit
here you go;
long rod
engine bay pair
Edited by welshpug
205Rallee
Matt, I've got a full set of Miles's gear rods and have used them for approximately 4 years, they really improved the gear change. I've got a full set of unused PTS 205 Rallye rose jointed rods but I've never fitted them as I can't see them being any better than Miles's rods. (And the design stops the rods popping off which the standard ones often do).Make sure you get a full set of the Gp N hard rubber engine/gearbox mounts and the change will be even better as the engine/box won't move around as much.
Edited by 205Rallee
