yeti-dj
Will A 306 Gti6 Rack Work?
yeti-dj
Hey people, haventriednsearching but can't find the answer that I'm sure someone will know.
I have a 205 gti with PAS but my rack is leaking so gonna replace it, I have a 306 gti6 phase 1 rack from the car I got my engine from but will this rack work ok in my 205. I can only find stuff on fitting the VTS rack?
I have the 306 rack and a square drive shaft so ready to fit if it will....
Can't wait to get my little car back on the road
j_turnell
Not done this personally, but id imagine it would be just the same as fitting a xsara rack, youll need to either cut the track rods down or swap for 205 items, as xsara/306 items are longer, the rest should just bolt up.
Same as fitting a Phase1 Xsara rack indeed, they are longer lock to lock than a 205 pas rack though.
you'll need a pas ram from a 5 speed car if you aren't running a 6 speed box.
yeti-dj
Pants, it's my RAM that's leaking and why I'm changing the rack, how much lock to lock will I miss if I just use the 306 as it is?
Or is my turning circle going to be horrible?
allye
*Slight hijack*
WP - if I fit a 6speed ram to a 205 rack will it reduce the lock so it does not foul?
not sure if it will be enough as the wheels are closer together, probably not quite.
not tried a 306 6 speed ram on a 205, but the other 306/9 rams are the same part number IIRC.
