john-melbourne
Temperature Sensor Gauge
john-melbourne
Hi Guys,
My temperature sensor inside the CTI doesnt go all the way down when completely cold, it starts about half way to the second bar, is this normal or should i change the sensor?
John
Slo
does it stay there when you turn it off?
john-melbourne
yep, first thing in a morning its starts from that position. goes up and down as normal but never starts horizontal so to speak.
Slo
sounds more like your clocks have been out at some point and the needles have been removed and put back in INcorrectly to me
Edited by Slo
john-melbourne
do you think this will effect the temperature readings at all?
Slo
how far up the guage from rest does it travel to when you imagine its normal temperature
john-melbourne
just above or about 3/4
Slo
from what you say the guage travel sounds like its in the right amount of swing from cold to normal. if you could borrow a spare clock or even pop out a friends sometime soon just to connect up to see what it reads when yours is at "normal" temparature, as in where yours usually goes to most of the time so youll know for sure. the temp light at the end of the guage will work properly regardless of where the temp guage is as long as its own sensor works and is wired up ok and the bulb works.
