samthornton1990
Head Gasket Gone Or Not?
samthornton1990
im unsure as to whether my heads gone.
There mayo in the filler pipes and breathers. But its using no water or oil....
I only drive it 15 miles to work the oil temp never really gets warm so could this be the problem that the journies arent long enough?
Anyone had this before?
Edited by samthornton1990
Slo
Yes mines exactly the same grey sludge in the oil breather cap and lots of it but uses no oil or water. Someone said it was probably just moisture building up inside the engine due to not getting hot enough before you stop it. Does it cut out and/or idle rough? particularly when starting it cold....
samthornton1990
Yeah that's the bugger.... phew bit of relief that. It clears out when I give it a good spanking. May have to beast it a bit on the way home from work. Hoping to sell it next month so this was worrying me a lot lol
samthornton1990
all good guys... needed a good warming up ;-)
