mech205eng
Fuel Pump Relay
mech205eng
fuel pump stopped priming on my 205, swapped some relays around and hey presto. I now need another relay to replace the one i removed, it is one of the 3 green ones in the fuse box, 12v 25 amp. I went to my local scrap yard on sunday and looked in the fuse box of every small, 4 cylinder, petrol injection car from the 90's i could find and most had 12v 30 amp relays. There was only 1 205 there and it was missing a fuse box. Does anybody know what car will carry the same relay with the same pin pattern? or where i can get a new one from? i've tried ebay and theres some on there but not sure if the pin pattern is the same
205 fuel pump relay is either on the left front chassis leg or next to the ecu, not in the fuse box,
the green relays are typically standard auto type, just check if they have 4 or 5 pins.
