pugpete1108
Dimensions For Driving Light Brackets Wanted
pugpete1108
i had to cut and grind my old brackets off as they were proper rusted on so was just going to make some out of steel bar but to save faffing around could someone who has one lying around (im sure there is a few :D ) make some basic measurments (length of each straight and hole position etc.)and let me know them?
cheers
pete
Ryan
They're still available new for about £5 a pair. The part number is 7416.05
If you want to make them, then from the bend of the L it's 80mm to the long end with an M6 stud at 70mm, and 45mm to the short end, with a 14mm hole centred 33mm from the bend.
pugpete1108
I'll buy new then if they're that cheap.
I assume that's a pug part number
Ryan
Peugeot part number yes. £2.71 each.
pugpete1108
Cheers dude. I just assumed they came as a pack with the driving lights.
Bonus
pugpete1108
When did you buy a set of these?
I went to my local today and got a print out which says no longer available??
Making them it is then
Ryan
It was 18 months ago when I bought them, so maybe they're become NLA since then. Assuming the dealer actually tried to order them, rather than just assuming they couldn't get them...
pugpete1108
Pass? Normally they are pretty good so.....
gavbrum
They are NFP (No Further Production) so no long available. I needed one and ended up just buying a pair of denji fog light mounting surrounds that have the brackets built in. The lights just fit in and screw on. Got them off someone on here.
