24seven
Sunroof Vacuum Seal (309)
24seven
I'm guessing the sunroof vacuum system on the 309 is the same as on 205s? If so where does the vacuum feed to the sunroof come into the engine bay? In the year since doing my VTS conversion I've not tried opening the sunroof until now, and it seems somewhere I've not connected something up right.
It's next to the brake servo, and should be fed from the brake servo vacuum pipe with a T off that goes to the vacuum reservoir box that's under the scuttle panel.
24seven
Cheers Anthony. :)
Guest
