damo
Central Locking
damo
Hi,
I have had three alarms removed from my CTI. The last problem I have is the central locking has stopped. I'm assuming i need a live somewhere so as so much cable came out from the fuse / relay box in the glover area to the drivers side I'm assuming the chaps been a little aggressive :)
Any idea what wire it is so the central locking motors have power?
Damo.
ade 4wd
Check fuse 7, should be 25amp.
On the drivers door motor there should be 12v on pin 3 of the 3 pin connector.
Alfie
Just received a central locking sensor and plip. Its working,I can hear it click at the unit. But no action at locks. No 7, 25 amp fuse ok so where is the relay for the circuit in relation to the relay/fuse board please?
