damo
Gti6 Conversion High Pressure Pas Pipe
damo
I've routed the PAS pipe under the engine basically next the the gearbox and sump.
Problem is the gti6 engine sits so low and the PAS metal pipe is around 10mm lower at the back / lowest point!
So if a smack a speed bump will split the pipe!
what have other people done with the PAS pipes under the car? its 306 PAS metal pipes.
Damo.
