HERMAN
Gti6 Fuel Rail Conversion To An-6 Fittings
HERMAN
After wanting to do it for a while I have actually got around to it.
The process was
1. Obtain 4 x AN-6 steel blanking plugs.
2. Drill the blanking plugs out to 7MM to fit the steel fuel tubes under the car and drill the other 2 out to 8MM and 10MM to suit the fuel rail.
3. Remove the fuel rail and fuel tubes and chop the ends of.
4. Silver solder/ Braze the fittings to the fuel rail and steels tubes.
5. Clean up and remove any flux.
6. Re assemble the system using fittings from Torques (Forum member user name powers also see his web site on ebay http://stores.ebay.co.uk/Torques-U-K)
I took the fuel rail to the local plating company and had it zinc and black plated to tidy it up.
Edited by HERMAN
Spiky
done the same to mine few years ago,
your engine bay looks so clean it's unreal :), top job there, want to come and clean mine?
Nice work, I think that's the neatest ever relocation of the fuel filter I've seen yet.
How much were the materials?
HERMAN
About £100 I think. Powers does a good discount. ;)
clen666
Good work, would you be interested in making another? :)
HERMAN
Yes no problem
marksorrento205
Looks really good mate. I love the cam covers!
HERMAN
Cool I am glad you like them because I was not sure.
Simes
Lovely - really neat job.
I've been experimenting with these also.
harryskid
Very smart !
HERMAN
Thanks guys
clen666
  On 4/14/2012 at 4:05 PM, HERMAN said:
Yes no problem
cool, I was expecting you to say bugger off!
How much would you charge?
HERMAN
What are you wanting me to do? If it is just to braze the fittings onto your fuel rail. Then I would just want the cost of the fittings.
Pm me
Neil
Edited by HERMAN
