scott-205gti
205 Gti 1.9 Rear Disc Beam 309 Gti
scott-205gti
Im looking at buying a 205 gti rear disc beam for a price of £40 it has been in a barn for about 5-8 years the owner said but he isnt sure if its off a 309 gti or 205 gti, will it still fit my car and if so what sort of problems would i need to check the beam for, i had a quick look around it and found that the rear discs are seized up and that it will require new brake lines. Also how hard are these to fit.Cheers
matty_gti
Wrong section bud, needs to be under 'suspension'.
Anyway, a 309 beam is wider than a 205 beam (not sure how much wider). May need to trim the plastic arches to stop them scrubbing, that's if it's a 309 beam. See if the trailing arms move and if they do see if there's any play. For a beam like that I'd just strip and rebuild it.
scott-205gti
Hi cheers for the reply, how hard are they to rebuild and hoe much in parts would it cost if i was to do it myself.Thanks
jord294
There is a few of us on here that can supply rebuilt beams.
Let someone else do the hard work
