Carbs4me
Anti Roll Bar Drop Links
Carbs4me
Hello,
My MOT is due next week, so i quicky had a look to see if there was any worn bushes or anything that they may fail my car on, my anti roll bar drop links where knackered...
So i go down to my local parts shop, order parts.
So i get round to fitting them last night, took the part off my 205, only to find that the ones i have been sent are about an inch taller(lenght) than my existing ones, and the thread on the link itself will not fit through the hole on my suppension. (The little hole near where you push your brake line on to)
I have koni suppension, could this be something to do with why the hole might be to little? or does it sound like its a wrong part?
Cheers,
sounds like 106 droplinks.
Carbs4me
looks like im gunna have to take them back...
and possibly see if pugoet still stock them if they cant get me the right parts.
S@m
As above, that sounds like 106 or saxo droplinks which have a m12 stud at the top, whereas 205 ones are m10.
And peugeot do still do them...but they cost £69.98+vat...yes really.
Sam
Carbs4me
OMG.... i was about to ring them literly fought they would be about 20-30quid each. Well the box says there for a 205 Gti but they wont go in the hole :(
take them back as they're obviously wrong, not an unheard of problem I'm afraid.
I got some FAI ones recently which fitted just fine, and said Xantia on the bag even though they were listed for a 205 :lol:
Edited by welshpug
Carbs4me
does it matter that they where longer than the ones currently fitted?
Do they have to be exactly the same size as the ones that came off?
EDIT:
I took them back at dinner, have to finish work now and hope that they get the right ones!
Edited by Carbs4me
Doesn't matter if they are slightly longer as long as the pair match, mine were the same length though.
chipstick
The Peugeot prices make your eyes water.
Motaquip are the preffered brand aren't they?
Edited by chipstick
They do fit but you have to space them out or you'll find that they may hit the hub on lock, There's around 6 lengths of these
Carbs4me
when i went back they had a diffrent set, which where exactly the same size in lenght and the threads where also the right size. Fitted them last only to find my bottom ball joints on both sides have gone too!
Cheers for the information tho!
