ryan_stdt
205 Gti6 Battery And Hand Brake Light Staying On When Ignition Is Off
ryan_stdt
hi
my 205 gti6 battery and hand brake light have started staying on permanently when the ignition is switched off, and is causing the battery to die after a few hours.
the battery itself is fine because if i leave the battery disconnected overnight the car still starts when the battery is reconnected
i have checked the fuses and the relay which seem fine.
cheers
You must have a short somewhere imo, check your wiring thoroughly & use it as little as possible until you find the problem.
g
ryan_stdt
Cheers, I've managed to clear the fault by taking the battery light wire off of the alternator and then reconnecting it. It been fine overnight so far
