jonb_5
Fuel Line - Filter To Rail
jonb_5
Hi
The fuel line in my car from the filter to the rail has some back insulation tape around it and looks a little old so am going to replace it, can anyone tell me what size i need to order, if not I will removed and measure....
Should I just replace with rubber or would braided hose be better?
Jon
Simes
8mm ID (internal diameter)
Rubber is fine.
Buy decent jubilee clips or similar to hold it together.
You can buy braided from
torques.co.uk
Size is AN6
Looks nice but starts to get pricey, especially when you use proper fittings
(Gratuitous picture)
Edited by Simes
What engine? 8v's are 6 or 7mm (can't remember which now), Mi16's are 8mm and GTi-6's are 10mm.
I personally find standard rubber hose fine, and has the benefit that you can easily see if it's starting to perish. Make sure you get hose that's specified for fuel injection though, as carb hose won't be rated to the required pressure.
Daviewonder
Make sure you get hose thats suitable for unleaded too, you'll be amazed at how much of it isn't.
BusEngineer
6mm on an 8v by memory
