Rob205
Which Wheel Bolts To Use With Eibach 15Mm Spacers?
Rob205
Hi Folks,
I want to put Eibach hubcentric spacers onto the rear wheels of my 205, really for ascetic reasons as I've got 309 wishbones and driveshafts pushing out the fronts.
I'm thinking 15mm spacers as I don't want to go too wide but Eibach don't sell the bolts with their spacers. Can anyone tell me which wheel bolts I will need for these and where I can get them from? Or do I have to go to studs?
Thanks in advance.
you need ones that are 15mm longer :)
if you want it to handle properly though just leave it as it is.
Batfink
Eibach can supply correct sized bolts. I usually order them in for customers.
Rob205
Hi, so can you supply these spacers and the accompanying extended bolts?
Thanks.
