omri617
Instrument Panel Lights Are Off
omri617
hi , starting to rebuild my 1992 GTI
when i turn on the lights , the background lights dont light
the hand break , normal front light , hight front light , fuel light and meter , water meter , and everything else works fine , but their background lights are always off
the dimmer which underneath the wheel is connected and seems to not make any differencd
what did i miss?
thanks
checked the fuses? also not uncommon for the dimmer t not work, try a bypass wire in its place.
DamirGTI
Try to fit a known good spare stalk for lights/indicators ... if that doesn't work , check the brake light switch and it's wiring (it's on top of the brake pedal) , most cars have dash lights wired via brake light switch so if there's a problem with dash/cruise illumination i usually check that first ..
Damir
omri617
will do that tomorrow
the indicator / light stalk was perfectly working when i started restoring the car
Damir , what should i check with the switch?
thanks
by the way , can you give me a link to the bulbs? i can't decide for sure which ones i need
omri617
Damir . how does the switch look like? i can't find it with all the mess down there
ade 4wd
When you switch on the side lights, do the side lights come on in the head lights? if not check fuse 13 should be 5 amp. Dont waste time checking the brake light switch as that is all different wiring.
omri617
yes when i turn on the main head lights the side lights work ( you mean the backlights ones , right?)
the horn doesn't blow , and there is now indication working (winkers) . also , the front washers dont work
omri617
checked the fuses . only the horn fuse was blown and i replaced it.
anyway , didn't work out for me . will take it to electrician and see what's going on
also , maybe i will disconnect the coming/leaving home system . too many wires over there!!
