cRaig
Brake Servo One Way Valve
cRaig
Hi there,
Im trying to fit the servo vacuum hose- which includes the white plastic one way valve at the servo end. How does this fit into the servo? It doesnt seem to fit through the hole, and even if it did fit, I cant see how it would be kept in.
I imagine its very straightforward, but its been too long!
Craig
Josh_Quant
Have you got the rubber seal that goes in the servo hole 1st?
Then just put some wd40 on the servo pipe then just push in
Edited by Josh_Quant
cRaig
Ahh, no. that makes sense. I shall start looking through my many boxes of crap for the rubber seal :)
Thanks (I knew it woudl be something obvious!)
Craig
