tomcolinjones
Where To Source A Be4 Gearbox Suitable For A Tu Conversion
tomcolinjones
Hello!
I have been searching for hours, Its not clear where I can source a BE4 gearbox, preferably with a low final drive for a small power tu block. I guess the final drives are exchangeable like the be1/3 with 4.41fd's from mi16's e.t.c?
thanks
Tom
johnnyboy666
from memory, picasso's, berlingo's I think 1.6 16v's
I think theres a few others with them
RossD
Mine came from a 1.6 8v Picasso. All the 1.6 Picasso's used the BE4.
307's also used it in 1.6 form, although it may have just been the 16v version in those.
You'll also need the intermediate bearing carrier from the donor car, P/N: 1807.H8
See my pics of the parts in my photobucket album. http://smg.photobucket.com/albums/v727/ross2482/BE4%20Gearbox/#!cpZZ1QQtppZZ16
Edited by RossD
johnnyboy666
Ive got a list of part number for the extra bits you'll need somewhere. Rather guted I had to sell my set up, but needed the cash at the time!
you will need to ensure the bearing carrier comes from the same donor vehicle as there's a few differing part numbers, which I believe have a different angle bellhousing.
I haven't confirmed it but I believe you may be able to use the BE4 from a DV6 engine too.
Edited by welshpug
tom-stratford
for the 106 gti convertion? could i have them :D
johnnyboy666
to use the box with manual cable clutch rather than hydraulic, check the link i put in the other thread :)
e8_pack
Been looking at this alot for the saxo/106/AX conversion:
A 306 1.8 16v nearside driveshaft is a direct fit for the 106/saxo conversion
O/S 1.6 8v Picasso shaft to be shortened to 330mm (use same picasso bearing carrier)
Picasso gearbox from 1.6 8v (TU Engine) (not 16v)
Use the later 37mm bearings for the BE hubs - turn the BE hubs down to 37mm to fit.
3mm shim to space out the BE hub - fits between bearing and hub flange (same ID as above) (shim can vary from 2-4mm)
Ensure you get the speedo drive to connect to the electrical speedo connector
Clutch cable from Firstline P/N: FKC 1078
Clutch fork from citroen/peugeot: 2117.58 (hyd to cable conv)
Clutch cable bracket: 2151.90 (hyd to cable conv)
BE1 gear selector lever heated and bent to run down back of box
I still need to source mounts at a reasonable price
anyone got a BE quaife for sale for my conversion.. :)
Edited by e8_pack
johnnyboy666
yeah its a much more involved conversion in 106/saxo/ax as theres not really a 'plug-and-play' driveshaft solution.
