allye
High Idle When Gti6 Is Hot
allye
This has happen a few times and only ever when the engine is up to temp, hot/warm.
After a run turn the car off, then turn it on again and it instantly revs up to about 3k RPM without me doing anything?
I usually turn it off, wait a few secs then back on and its fine :huh:
Any ideas?
Thanks, Ali
chipstick
ICV or inlet temp sensor?
allye
I thought idle control valve, does these fail?
Have got one kicking about Dan!?
chipstick
Quite commonly sold on the OC so I'm guessing so. Afraid not Allye!
Very common on most 06's, they moved away from the good old Bosch ones
allye
So, replace my ICV for a bosch one and jobs a goodun?
rallyeash
clean it
allye
clean it
Sounds like the cheap route.
Paul_13
Need to do this on mine, probably the cause of my stalling
allye
Aaaaahhhhh! Another symptom of mine, a dip of clutch and a blip usually clears it. Will def clean the ICV tomorrow.
No, the Bosch ICV's are very good, the Mag M ones are pretty crap in comparison which are a completely different type to the 2 or 3 wire bosch ones
allye
Just to follow this up, I indeed had a bosch ICV, gave it a bloody clean out and got all the crap out of the inside and now it starts and runs much better, also doesn't do the high idle thing any more. Good times!
