daneldridge23
309 Drive Shaft Lenghts?
daneldridge23
Can any one measure the lengths of 309 shafts I just got what I thought were 309 ones and are exactly the same as my ones!!! Have I been duped!
Dan
They are only about 10mm or so longer AFAIK, so will look very close.
Also, they are typically measured compressed, so might well show a difference then.
It's far from unheard of for incorrect driveshafts being supplied though!
daneldridge23
i hope so! they are to the mm as they sit in my shed!
allanallen
A quick search turned this up-
205 driveshaft length (mm)
RH - 840
LH - 600
309 driveshaft length (mm)
RH - 850
LH - 610
I would imagine they'll be compressed lengths.
Al
Al's right. 24/25 splines.
Discostu
I would never 'dupe' anyone
As I said previously I bought them new as being 309 driveshafts (i have supplied you with a copy of the original invoice) and have been using them alongside 309 bottom arms without issue, so never thought to doubt that they weren't. If there is an issue we will have to sort something out.
Anyway, I have found this link that ,might help:
http://websworld.org/marcel/309/tech/shafts.html
Let me know the results of any measurments you take
Thanks, Stu
Edited by Discostu
