joe1joe
Trailing Arm Shaft Internal Id
joe1joe
I am rebuilding my rear beam (309 gti) and i will be using 23mm torsion bars and 25mm arb.
I have measured the internal dimension of the trailing arm shafts to be 30.85mm (new genuine items)
Now the question is will the trailing arm shafts happily except a 30mm arb at a later date if i decide to, or will a larger arb to traling arm shaft clearance be needed?
stu8v
I doubt very much you will ever need to use a 30mm antiroll bar
tell miles that :lol:
joe1joe
Well i thought it would be best to build the beam to give me the option to run a 30mm arb later on .... It Wouldnt cost me anything!
allanallen
That should be fine joe, we usually bore them out to 31mm so your not far off that.
Al
Yes there are fine with a 30mm bar in them, Got one like that already
