kyepan
Underbody Fuel Hose Clips -Help On Service Box Please
kyepan
Looking at service box - it could be one of about ten clips..
To be honest, usually i'm fine with service box, but it doesn't seem to have a car filter on the clips section, or it doesn't work, i've never looked at the clips sections, or the plugs section, managed to find the plugs i was looking for because it's visually distinct.
.. but this clip.. i do need a bit of help finding the part number for, i know it's two hoses wide, and has a lug that goes through the body.. but i cant find it/
cheers
J
Ryan
The clips/connectors/bolt/etc sections aren't the best. You can't filter by model, and a lot of 205-era stuff is completely missing from them anyway.
The clips should be listed in the normal parts section, somewhere under fuel piping.
Edited by Ryan
kyepan
yep i can see a bunch of them but don't know which is the right one!!
Ryan
If I had to guess I'd say it looks like #10 is the 1.9 clips (two fuel pipes + one brake pipe), and #14 is the 1.6 clips (two fuel pipes only).
#10 = 1565 61
#14 = 2287 07
I'd agree with Ryan there, the clips do look to be 1.6/1.9+base model
#10 is £1.38, #14 is 79p, you need 6 :)
kyepan
Thanks guys, I was clearly looking in the wrong place! As you've got it as part of the fuel system!
