samthornton1990
[rally_prep] 205 Road Rally Project
Cathal
What kinda gearbox are you putting into her? Other question can you make the 205 wheel base wider by using different wishbones?
samthornton1990
I've sold the car... if I get another one though it'll be the 1600 box with some sort of diff...
brumster
From standard, yes, you can fit 309 lower arms and shafts - the additional track is marginal though on 1.9 hubs, from memory the shafts are 10mm longer each side so I guess the track increases to a similar order.
Otherwise you're looking at group-A style wishbones or else some custom jobbies like Colin Satchell's, at which point you can pretty much choose any track you like :)
