Matt205
What Is This?
Matt205
Well, I'm not sure what it is, so what is it?
Where should it connect to and where does it normally mount?
Thanks.
charcoal canister evaporation solenoid, most 205's will not have a charcoal canister to connect to, blank the port off on the inlet.
Edited by welshpug
Matt205
Great. Thanks Welshpug
However, if I am right, if you do not have it connected the ecu will illuminate the engine management light on the dash (if you have it wired in)
There are two options, leave it plugged in doing nothing, or I believe there is a work around by installing a resistor in its place to fool the ECU into thinking all is present and correct.
