daneldridge23
Clutch Thrust Bearing
daneldridge23
hi guys recived my new clutch assembly and noticed that the bearing is different the new one is totally different?? what have they sent me and what part no is my old one
IMG083 new one
IMG081 old one
old one is a BE1 bearing, new one is BE3, not compatible.
large washer is missing from under the mounting stud too.
Edited by welshpug
daneldridge23
i bought this as a complete clutch kit, does that mean this is wrong to?
no, the pressure plate and friction plate as the same, if the BE1 bearing is good then just re-use it.
its what I did when I fitted an MI16 clutch and flywheel to my 1.9 8 valve.
daneldridge23
it looks ok, i dont even kno what box it is yet so im gonna experiment with a few see whats gonna suit it best, what washer are you on about where the engine mount stud is?
In this picture thee sdhould be a thick large washer under the miounting stud which you can see in the pic below;
g
