daneldridge23
Cam Timing And Flywheel
daneldridge23
Hi guys i have fit my cams back in my head, im using piper pullys.
My questions are, i have found tdc on cylinder no1 and marked it on my crank pully.
I have made a pointer and fixed it to the block and then found maximum lift on the valves as there are no dowl holes, marked everything up and put the belt on.
Am i right so far?
Im now ready to put the flywheel back on. Will it be in the right place on its dowl beacause i keep thinking that the two teeth missing on the ballencer should be tdc,
Can sombody give me some advice or am i getting confused being this is my first time building an engine
Dan
The missing teeth on a Motronic flywheel are not at TDC. Have a look on Petert's website here for info on determining TDC using the flywheel
personally i would fit the standard pulleys first to get everything timed correctly then swap the pulleys, xu's pin up mid way not at tdc.
daneldridge23
Its not the timing, im pretty sure im correct, im worried about the tly wheel senser and the flywheel not being in the right place
Dan
daneldridge23
Excuse my limeted lnoledge on timeing but what are the two missing teeth for, and judgeing by the picture and the 12 and 13 tooth im preety sure the timing is correct!
To give the ECU (via the crank sensor) a known reference point to know when the flywheel has turned a complete revolution.
flywheel can't go on wrong as theres a dowel, missing teeth iirc are at 114.5 degrees.
daneldridge23
I understand now thanks alot for your help
Always appreciated
Dan
