td_dan
Couple Of Stdt Questions
td_dan
firstly what size is the front arb? is it worth upgrading to a 1.9 one?
also is the clutch push or pull type?
Same front ARB as a GTi. Rear ARB is smaller (16mm IIRC) and a 19mm GTi rear ARB is a good upgrade.
Clutch is a 215mm push-type - pull type clutches were never used on 205/309 models, only later cars.
td_dan
thanks for your quick reply mate greatly appreciated :)
td_dan
Is the 19mm rear arb from a 1.6 or 1.9 or doesnt it matter?
Strictly_Derv
The same I think. Does make a big difference to the handling I found but I put a 1.9 beam on which had thicker TB's.
I have one and the GTI TB's sat in the garage if your interested ;)
Edited by Strictly_Derv
They're identical - both 19mm
td_dan
how much for the arb mate. and if the tbs will fit then how much for them aswell.
cheers anthony for clarifying
Strictly_Derv
I tried PM'ing you but can't, think you need to clear your inbox
td_dan
Try now
