tommy gun
106 Gti Rad On 205 Gti6
tommy gun
hi guys ive been thinking of fitting a 106 rad to my 205 gti6 but im thinking it wont be big enough to cool the engine.
just fancyed an engine bay clean up and thought i could lose the header tank this way, the car will be when finished used for trank days so i dont want to cook it every time in on the track.
anyone done it before?
omega
think loseing the header tank is a bad idea.
you wouldn't be in fitting the 106 gti rad, it has an integrated header tank.
dcc
wrote some sort of reply then decided not to post it. I like the idea of no header tank. Might be worth a gander... Have a few spare hoses around to try out at somepoint
allye
Its been done with a GTI6 205, can't remember who's but its somewhere!
tommy gun
does it matter thought that the highest point of the header tank on the rad will be lower than the cilinder head by a little.
it wont be by much, the water isn't any higher than the thermostat housing.
It will work, but will be a pain to bleed - 306's are like this for example.
S@m
You will need to extend the rad mounted header tank with the 'special tool'.................more commonly know as an antifreeze bottle with the bottom cut off and a couple of rubber o rings. Thats the only way i seem to bleed 306's, xsaras etc. successfully.
Sam
Indeed - that's the way I do it too, but it's still a faff compared to the pretty much self-bleeding standard 205 GTi setup.
Matt180
I was using one of these sierra cossie rads on mine. Bit of a tight fit but did the job well.
My link
Im not using it on my current s/c setup so might be open to offers ;)
tommy gun
willl it still work if it was lower than the standard 205 setup. i no it will be a nightmaire to bleed but as long as it work i can live with that.
Matt180
Yeah i had it mounted low to allow air flow to the TB's/filter. Had no problems bleeding it at all.
can see how low it is here, could go lower still with new lower mount.
rallyeash
gti6 is easy to bleed, i just used a large funnel the other day and no problem.
Renault 5 GT Turbo radiator if your looking for space... (twice as thick)
runs along side the oil cooler...
can't even tell
tommy gun
these are using the standard header tank arnt they. if u used the 106 rad with the header tank on the side will it still work if lowered for tbs.
stef205
Im using the same as rallyeash tho you can tell on mine, works very well although i had a outlet welded to return to the header tank
rallyeash
should have patented my design!
danny56712
I believe a Citroen box rad is better than the 106 one for size
stef205
haha yeah you should have, i did pm' you back along about it
Edited by stef205
